Need some help 5.3 no start
mark84k5
michigan
I will info dump first to get any helping hands up to speed. In the last couple months I have had a tone of issues related to random misfires dealing with plugged cats. So in that time I have put a new mad,map, 4- o2 sensors, pulled cats out. New plugs wires, cam and crank position sensors, and fuel pressure regulator. The other day on the way to family’s house on Xmas it died on me. Had to get a tow. Just died while doing 50, threw it in neutral and coasted to a safe spot. It cranks and has fuel pressure and spark. It will not start. What should I do?
yeah either of the new sensors cam or crank could be the culprit. What brand are the new sensors ? sloppy terminals the connectors can loose continuity
Did you do a crank position sensor relearn when you replaced it?
What codes does it have?
Start checking and cleaning all engine harness grounds.
Sensors are oem used sensors from good running motors. I will get a scanner. Didn’t do a relearn I don’t know how but will try to figure it out.
I know some may think why am I using used sensors but I have 3- 5.3 that ran when pulled sitting around and I have been shotgunning parts to get it running. Not ideal but is in the teens (temperature) here and I’m just trying to get it running!
oem sensors should be fine, some aftermarket can give dirty signals. I would be looking at connections, Pulling codes will help narrow down the system.
Went a bought a cheap code reader today and it kept saying “no codes” I will take it back and try a more expensive one tomorrow.
The check engine light is on so there is definitely codes but for some reason the reader wouldn’t pick them up.
I think you need the crank sensor for spark and fuel, but cam sensor only affects fuel timing, like it should start with a bad cam sensor. I don't have proof of this, so some one can correct me. If it's sparking, you probably have a crank signal. For fuel, a stethoscope on an injector should tell you what it's doing.
To test your code reader, you could unplug a sensor to see if the code shows up. You should be able to run with a bad MAP sensor, as it's usually secondary, but a MAF that's wrong can screw everything up. Another free test is to leave either the MAF or the MAP unplugged and see if it's any different.
In the teens today and it’s be snow off and on all day. Got off work around 4 and didn’t have time to play with it. I’ll try some of those ideas tomorrow and give an update. Happy new years.IMG_7119.jpeg
Nice that it's so warm there. Happy New Years and fix it next year!
