CutlassKid85
Registered Member
Alright guys my brother is buying my truck a cam for X-mas just need to pick it out. I'm thinking about Lunati's VooDoo cams.
I've got a 77k5 with a 350. Already has Eddy carb, Rpm airgap intake, and headers and exhaust.
Here's what I'm looking at. I'm leaning toward the last two, just don't have any experience with picking out the right cam and would really appreciate what yall think would work.
Lunati 60100LK
Very strong torque and increased HP for mild performance rebuilds. Compatible with stock type fuel injection. Works great for pleasure/ski boats, and mild towing applications. Excellent in oval port engines
Advertised Duration :250°/256°
Duration @ .050 IN/EX : 207°/213°
Gross Valve lift IN/EX.437''/.454''
LSA and ICL112/108
RPM Range:Idle-5000
Lunati 60101LK
Best mild performance cam. Works excellent in fuel injection applications. Makes approximately 19'' vacuum at idle. Great for performance oriented marine applications and heavy duty 454 Dually towing applications. Perfect ''STREET ROD'' cam. Has SLIGHTLY noticeable idle, works with stock converter, A/C, power brakes and STOCK valve springs in MOST cases. Excellent in oval port engines.
Advertised Duration :256°/262°
Duration @ .050 IN/EX : 213°/219°
Gross Valve lift IN/EX.454''/.468''
LSA and ICL112/108
RPM Range:1000-5500
Lunati 60102LK
Mid-level performance street cam with excellent drivability. Exceptional replacement for ''muscle car type cams'' with automatic transmissions. Works well with stock type exhaust manifolds and dual plane intake with mild 4 bbl carb. This is an AWESOME 4x4 and Performance Marine cam where ''DRY'' exhaust is used. Improved valve springs and roller rockers are recommended. Excellent in oval port engines.
Advertised Duration :262°/268°
Duration @ .050 IN/EX : 219°/227°
Gross Valve lift IN/EX.468''/.489''
LSA and ICL112/108
RPM Range:1400-5800
Lunati 60100LK
LSA and ICL112/108
RPM Range:Idle-5000
Lunati 60101LK
LSA and ICL112/108
RPM Range:1000-5500
Lunati 60102LK
LSA and ICL112/108
RPM Range:1400-5800
