w0lf
Registered Member
rjfguitar said:No prob man...
Ok, your stock tires should be around the same weight rating as my stock E rated Michelins were. 3600lbs at 80psi. Times 4 tires =14,400lbs total weight that you could essentially make that truck weigh and the tires hold it up. For one, you have a small block, so there is 500+ lbs less on the front end from the lack of a Dmax.
Now, say you are going to pull a heavy gooseneck. Most 'necks are going to give somehere between a 10-20% tongue weight depending on how you load your trailer. If you were going to pull a heavy 'neck that say weighs 15K (the max you probably can tow, if over the manu' rating) you are going to have a tongue weight of around say 2K or so.
Now, back to your tires. Your truck probably weighs 6,500lbs in stock condition, thats essentially around 1,625lbs on each tire. With the gooseneck, that puts you around 2125lbs on each tire, roughly. Thats a long way from 3K+ that your tires are rated at. Where you could run into some weight issues is filling the bed with something really heavy. Say sod, that crap is heavy.... Then if you could manage to stuff 3-4K on the bed somehow you could creep up to where an E rated tire is needed, but there again no Dmax so there is an extra 500+lbs not on the heavy part of the truck, which is the front end.
A slightly larger tire with a load D rating will be adequit. I run 33x12.50x16.5 Cooper Discoverers on my Ram that has a much heavier Cummins up front and a big D60. They have a 2,910lbs at 50psi rating and it's still weight capacity to pull my gooseneck with anything on it. BUT, I never fill my bed full of heavy stuff, I just pull a trailer if it's anything big or heavy enough to matter.
GM, tire companies, internet sites are going to say you need an E rated tire, because thats what the manufacturer calls for, but you just have to read between the lines and figure out what you are going to actually use the truck for, and unfortunately, most of these heavy duty trucks don't get used for much more than commuter cars anyway.
Does that help some?
wow, that is a GREAT explanation, thank you for taking the time to kick me some knowledge.
The heaviest usage model i have right now would be as follows:
Approx 1000 lbs in bed of truck
towing heavy trailer with 2 quads, gear, etc. weighing around 6000 lbs
There is a chance that we get a 21' toy hauler, which would then mess this all up, but it would move all the weight onto the tongue, and out of the bed. i don't know what this weighs (est 10k based on what the new ones are), but does that change my decison basis now any?
). If you want to stick with the stock rims, I agree that the 255/85 bfg work well. but there is not alot of floatation to them.
