I'm looking for suggestions to make or buy a new fuel line to replace a leaky hose. I need to be on the highway in a week, but I have other work to do before that which requires it to run. When I did the EFI conversion in 2006 I had a buddy who worked at a hydraulic supply house and we just walked in one night and whipped some lines up. This is PTFE hose with stainless braid over it, something like 5' long. The fuel rail is Camaro TPI, with fittings at the front and it runs behind the water pump and over to the PS frame rail, connecting to a hardline behind the spring shackle. The lines from the tank and up the frame are from a TBI Blazer. I'm pretty sure I had all the fuel lines from that TBI Blazer at the time, but couldn't use the engine portion due to the major differences in TBI and TPI. So the stock fittings are an O-ring type, but my custom hoses use an AN (flare) type. I have an adapter at the fuel rail that is supposedly for a power steering pump. This all worked fine for the last 12 years, but now there is a leak mid-hose (actually I'll call that 10 years, pretty sure the leak started a while back, but it's been getting progressively worse).
So can I buy TPI-type fuel fittings at the local store and just clamp rubber hose onto them?
Can teflon/braided hose be spliced and repaired?
Is a local shop likely to be able to build a duplicate on the quick? From what I'm seeing, that hose is like $1/inch, but I might still pay it if it's drop-in and go.
