hidesertwheelin
What is the best and safest way to do it? Do I need to worry about sparks blowing my ass up? I was thinking about using either my 3" air saw or my 4" grinder with a cutting wheel. Is there another way I should do it?
yes, just drop the tank, with the amount of work to cut out a hole, patch it back up or whatever, it only takes about 20-30 mins do completely drop a tank and get the old pump out. Nuther 30 mins to reinstall it and everything is still as was when new.![]()
30 minutes? u obviously dont have a skid plate or have rust lol
,,, just that i have had more than one of before, i would guess maybe 45 mins for the first time, lube the hell out of those bolts and let'em soak. it's really not that bad to drop it, alittle more of a pain if you have a decent amount of fuel in it, but even still, use a floor jack, and a few pieces of wood, and a helper to assist in lowering it, remove all the gas when it's on the ground so it's easier to reinstall.yes, just drop the tank, with the amount of work to cut out a hole, patch it back up or whatever, it only takes about 20-30 mins do completely drop a tank and get the old pump out. Nuther 30 mins to reinstall it and everything is still as was when new.![]()
