NEEDED : sm465 from a 208 equipped truck
Stomis
Professional Amateur
Roseland VA/PtPleasant NJ
Must be 32 spline on the clutch side no 10 spline
Must have or previously had a 208 or 241 behind it
Must be functional, preferably rebuilt
PM me, reply, email me [email protected], hell you can call me if you want to PM and ask for my number
The only thing that I ask is that if your going to ask a higher price because its rebuilt I expect to see some sort of receipt.
my buddy has one. i'm not sure what the input spline count is though. would be pricey to ship.
i will check the splines for ya.
I don't believe the SM465 came with a 32 spline input(clutch side), they were all 10 spline input.
The 85-up SM465's had a long 32 spline output shaft, however. There's a pic in this thread;
http://coloradok5.com/forums/showthread.php?t=203741
and yes, the 32 spline SM465's had 208/241, and even 205's behind them.
I thought I remember reading that the clutch side changed also. If not I turned down a rebuilt local trans for $100, better facking call that kid. ****....
As Jimbo* stated , all SM465's have a 10 spline input shaft , the output shaft is what changed , from 10 spline to 32 spline.
Thank you for clarifying that. I should have read through the site I got my information off of better...
Bolox I need to call that kid now...
Ok so if my truck came with one in 87 then I need a long shaft 32 spline OUTPUT correct?
Correct ,the stock tranny (SM465) would be one with a 32 spline output.
As long as the SM465 had a NP208 or a NP241 behind it ,or if it was from an 86-91 one ton with a NP205 , it will have a 32 spline output.
