Pulled the knuckles off a dana 60 i just got. And I never seen a king pin like this. Is this something someone did because they stripped the Allen bolt?
Never understood that and the offset ball joint “caps” or whatever. I really like the plastic shim between the knuckle and spindle/hub. Easy enough to set once and forget it. Caster is not adjusted there anyway.
