delete please
PARTING OUT, any questions call/text 607-240-9706. I want to sell/part it and buy something done. I will sell EVERYTHING truck related, including the running 454, 427 and NV4500, and parts that I have for $4500.
Truck was a 2wd dually, had the frame shortened 14" and 6" off the back. Pulled the 2wd stuff, used DIY4X B-52 kit and used 4" HD springs. Rear uses stock springs, and 4wd hangers with 2wd rear for poor man's shackle flip.
Interior is in decent shape. Back seat is on tracks, and folds down into a bed.
Has TDC Cummins crossmember and motor mounts, new urethane mounts. $400 (take some time getting it out since it's welded.
DIY4X front and rear bumpers. $1000
427 tall deck with all the TBI stuff. $500
454 carbed but have TBI stuff, $600
NV4500 2wd tranny from a 97, has the GM bell as well as one for a Cummins. $600
Divorced Ford 205/crossmember, will need to be reworked to mount, new bushings. $150
39" TSLs, tread is like new, still has the nipples on them. Mounted on 15x10 8 lug wagon wheels. $1200
High pinion Dana 60 front, has less than 50k when pulled, put all new kingpin stuff, not on yet but 3/4 ton brake brackets from Blackbirds, crossover steering, 79 style lockouts, 4.10s. $1200
14b full floater from 1980 van, 4.09s Govlock, haven't done anything to it other than the spring perches and shock mounts. Probly need brakes. $250
New body bushing and 1" body lift from ORD.
New cut out fender flares, not installed.
Cowl hood, cab visor.
Body is real solid, only rust is cab corners and coupls spots on rocker panels. Everywhere else is rock solid, underneath is still painted black, body mounts solid as well.
Fenders are nice, doors are nice but have stress cracks from the west coast mirrors. Box is solid with one small rust spot on the driver side rear, also has a black tonnaue cover with no tears. Has a frame that bolts to the box, can open the tailgate with the tonnaue still snapped on.
Truck was built by Choo Choo Customs, also a Sierra so has all the options. Power windows, locks, tilt, cruise, air, delay wipers, custom seats, rear is on tracks, slide it forward and lays down into a bed. Has real wood trim, needs work but nice when done.
I also have a tilt column for a 4-speed, and I think pedals.
Bunch of other stuff too, GM round 205, 1350 CV front driveshaft from a Super Duty, (get the $100 flange from High Angle) extra 4 core radiator, driveshafts, tilt column for stick.
I know there is more, but can't think right now.
Pics are in my sig. Any questions feel free to call.
