New 14 Bolt Spool Available
Why pay money for a spool when you can weld it up /forums/images/graemlins/dunno.gif Does the same thing /forums/images/graemlins/screwy.gif Someone please explain /forums/images/graemlins/confused.gif
You're right welding will work just as well. In a situation like a gear change where a person might not already have the correct carrier this is perfect and less than a Detroit. /forums/images/graemlins/thumb.gif
Besides think of the [sparkle]BLING!![/sparkle] /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif
[ QUOTE ]
[/ QUOTE ]
Because it is stronger than a welded carrier.
If anyone wants one, I'm a dealer, hit me up. /forums/images/graemlins/thumb.gif
Well I'd buy one but there is two problems there.....
1) I don't have a 14b FF yet!
2) I am a poor university student
/forums/images/graemlins/rotfl.gif
[ QUOTE ]
[/ QUOTE ]
Well I don't sell welders but I think the use of one is in your near future.
I've always thought about welding up my 12b but have always been a little uneasy to do so. Would it be better to weld the front so it disengaged when you were on the street (but its a 10b ... /forums/images/graemlins/ooo.gif) or the rear diff and have the tires chirpin all the time and wear down my precious tires that I can't afford to replace! /forums/images/graemlins/1zhelp.gif
[ QUOTE ]
[/ QUOTE ]
If you can't afford to break stuff, or wear down your tires quick, I'd leave it open at both ends and hone your driving skills instead. Being locked is cool, but open diffs will still get you places you never thought you could go.
Rene
Hmmm, you're probably right....unfortunately /forums/images/graemlins/shocked.gif Well, I think I may turn my attention this summer to finding a BBC I can freshen up a bit. I need more powa!!! The 305 just doesn't cut it... /forums/images/graemlins/angryfire.gif
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Rene
[/ QUOTE ]
I agree with you on the tire wear and harshness thing....but you guys that don't have lockers don't even know what you're missing. Once you're locked you'll think your truck can go through ANYTHING. /forums/images/graemlins/rotfl.gif
Body damage is the usual result. /forums/images/graemlins/thumb.gif /forums/images/graemlins/histerical.gif
I could deal with a little body damage cause you can still use your truck when its bashed up. But broken axle shafts and balding tires affect the performance. /forums/images/graemlins/frown.gif So I am still undecided on what to do.
[ QUOTE ]
[/ QUOTE ]
You mean it can't? /forums/images/graemlins/confused.gif
Bummer /forums/images/graemlins/frown.gif
Seriously, I do agree. Lockers give more traction improvement than gnarly tires. Even more ground clearance can't compete.
[ QUOTE ]
Can it be used to replace a government locker diff. or is it only good for the open 14bff?
[/ QUOTE ]
Nope, it can go in either.
[ QUOTE ]
[/ QUOTE ]
This spool is a replacement carrier, not an insert to be used inside the original carrier.
thats the one good thing bout this...is if ya got a gov loc you can get rid of it for a spool...instead of where a detroit will only drop in and only in an open carrier /forums/images/graemlins/thumb.gif
Oh, I forgot, this spool is available in a 4.10 type carrier only. They are not going to produce one for OE 4.56+ gears so anything in that range will have to be aftermarket thick gears.
id like to get one but my truck has to get to the trails.also snow and ice driving here in pa would be more of a challenge.the priuce seems to be in a good range though.i broke my detrit last year.so i had to go back to open diff.i still have to get ahold of tractech to see what i can do about replacment parts to fix my detroit.this would be a nice solid replacement.and the 14 bolt is so easy to set up that if you could change from open to locked in under an hour.4 hours to let the silicone dry up and refill the diff. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
[ QUOTE ]
[/ QUOTE ]
IMO it's a good thing. They should just do away with that carrier and all its associated gearsets and produce gears lower than 5.13 instead.
Nobody has that carrier anyway. They should just ditch it.
