New 203/205 doubler,triple stick and drive shafts
rfda_454
Gillette Wyoming
This is a New Never installed ORD Doubler, Rebuilt cases comes with Crossmember built to fit a gen 1 K5, Flange on the back.
Has a 27 Spline input with a th350 adapter on it
i also have the 32 Spline shaft and th400 adapter.
Brand New High Angle drive shafts,, 1350CV on the rear W/ Flange
1310CV on the Front. These are 100% new never installed
ORD Triple stick shifter also new Never installed.
They are a little dusty looking from being moved and stored.
All Together $1750
I Also Have a Th400 With short tail shaft for the 203 Trans is in Good Running Condition with torque converter for $400
if you go the way of parting this, i'm seriously interested in the crossmember. pm me if you want to do this.
Hey I know Bryan is buying some parts from you.
I need to hook a 400 to a 203 for a doubler.
I'm interested in Your trans, because I believe the TH400 has a different output shaft for a 203.and if you have a 32 spline input for a 203 if you have any extra.
I need an adaptor also, if you have any extra
Haven't measured em yet. I'm out of town till next week but ill check and.get.back to you when I get back
Front won't work for sure. Is is 30 collapsed
Rear won't work right now either. With the 208 I'm at 30 on the rear too. If/when I go to the 205 it would be just about right
Can always shorten it. What is the setup I may have another set that will work its out of a k5 th400/208.
83 Jimmy..465/208 (LONG) 14 bolt moved back 1" w/zero rate...front D60 moved forward 1" w/custom springs
