You might have had an injector get stuck and it flodded that cylinder,it'll make a bad knock that rounds like a bad rod bearing when they do that...sounds like some crud held the injector open,then it finally washed thru...could have been a chunk of carbon that broke loose in the cylinder or under the head of a intake valve too..
My older brother had a 307 V8 in a '68 Impala,one day at McDonalds some friends with muscle cars pulled along side of his car and they all started revving their engines up to the redline just for kicks...suddenly,after he let off the gas,his engine starts rapping BAD,so he shut it right off,and he had it towed to his garage...next day he pulls the engine out,took it ALL apart,and found NO sign of bearing wear or scores on the crank,the oil pump was fine,no crud in it ,etc..when he took the drivers side head off,he saw a chunk of carbon that was shaped like a half-moon--and under the head of the intake valve there was a blob of charcoal looking crud stuck to it,with a half moon peice missing !..he did a quickie valve job,just took all the valves out and wire brushed the carbon off the intakes,and lapped them,then itteraly threw it back together,and it ran a lot better than ever before,and no more noises!...I bet a bit of Marvel Mystery oil dumped down the carb and some "goosing" would have "fixed" it without doing anything!..but he feared the worst and didn't want to ruin the engine had it really spun a bearing..
