alright well i took it for a test drive. the truck idles fine. The timing is set to zero with the black and brown wire unhooked. I have the harmonic balencer marked every 90 degrees in white (when i was adjusting the valves) and for the etched timing mark, its marked in yellow. When the timing light is on the truck and its idleing, you will see the yellow mark, and then every so often you will see the yellow and a white mark also near the left side of the timing mark if you are facing the front of the truck. i am not sure why this would be doing this unless my 87 octane gas isnt high enough and the knock sensor is retarting the timing...???? On the test run when applying gas the truck backfires through the intake and you cannot accellerate hard at all otherwise it will backfire. i am currently running my stock prom chip. any suggestions?
