ok, that sounds easy enough, just watch data in WinALDL. I am pretty sure ssyorks tbi is modded for adjustable fpr.
Are you referring to break in or general tuning?
I'm just curious if we see it going lean on break in which table (BPW or VE table) should we adjust to get it into check for the 20 min of 2k rpm? After we have cam broke in I am fairly competent we can get it tuned.
Here is another sorta related questions but mostly for my own knowledge. What the max number you ever want to see the BPW set at? I've read if its too long it can overheat the injector???
So by the looks of this, 7747 and 8747 are swapable? Just some of the tables on the chip are different?
The TH400 uses a Kickdown relay that is wired to the ECM.
I can not verify that. Listen to these other guys! All of my very limited knowledge has been learned on this truck, and definitely have way more to learn. Here is what I started with and what I have now. Started with a 1990 3/4 ton with a 5.7 and a 4 speed. I put an nv4500 in and everything worked great. Then I added Vortec heads off a 96 a few years later. I daily drove it with only a little stumble when I floored it and an occasional check engine light that never stayed on. All on a stock chip in an 8747 computer. Then I changed to a fuel pump out of a 96 and did the tbi mods and it ran great still on the 8747 w/stock, chip. Now I added a new cam, the bottom side of a bb tbi unit, the fuel pod off of my old small block tbi with the pressure maxed out, 7747 comp, and a stock bb tbi chip from a manuel tranny with the egr and knock sensor turned off,since I have neither of these. I haven't hooked a computer up yet, but will on the first day of bb on Hells. It runs great now, no stumbles or bobbles anywhere. Had a mechanic friend drive it also and he said it feels and sounds good too. Still want to hook up the computer and see what it looks like and also keep learning.
