New cam
Using winaldl, i have mine set to the 7747 setting. Does 7747 and 8747 use the same setting? Or am i just out of whack on my computers?
I'm not 100% sure if WinALDL work on both 7747 and 8747. The WinALDL website only shows it's supporting the 7747. Both computers are 160 baud rate, and use the same serial communication wiring. I think the 8747 is likely to work, or mostly work, with WinALDL, but I'm not enough of a 8747 expert to be 100% sure. Maybe just the VE and Spark tables are only going to 3200 RPM's with the 8747 and WinALDL?:confused:
dave w
dave w
Well then TP should also work?
So we finally data logged my stuff on Friday and the BLM table was between 122-134 across the board with my conglomeration of parts. The only code I had from Moab was a vss code. That was good to see. Norby smoothed it out and it was running good. Just couldn't get a chip to burn. Then a rod bearing started making noise on Sat so we shut her down before it got any worse.
