Drobb's_85
Registered Member
Ok heres the deal, I had a new crate 350 goodwrench along with a new Edelbrock 1406 electric choke carb installed on my 85 K10 about a month ago. The truck has ran great for the most part(seemed just a tiny bit rich) until the other day. I started it up cold and immediatly noticed a change in the sound. Warmed it up and got it off high idle and woah it ran rough. Shook the whole cab and sounded horrible, but as soon as you got above idle speed it seemed to run fine like it had been? Whenever you come to a stop and idle it ran like crap, shaking and just sounded wierd and you could also smell raw gas around it and the exhaust. Its only got 390 miles on the new engine/carb combo. I took it to my mechanic who installed the engine and he definatly agreed that it was running to rich and that it kept trying to flood out. Today he called and said that it was running better after some adjustments but that it could possibly need the jets changed to a different size eventually. He also thinks that it possibly could be a defective carb. So I picked it up and it ran "ALMOST" like it did when brand new, just sounded a bit different but no more shaking or rough idling. Well it didnt last long. On my way home from work it started doing the same thing, rough idle, raw gas smell, it barely stays running at stoplights but anything above idle it seems to run fine? What the heck, this thing is almost brand new, it shouldnt be having these kind of problems. If it needed different jets, how come it didnt need them for the first 390 miles? Do you think this Edelbrock is just a bad one out of the bunch or what? What do yall think, I nedd your help. Thanks sorry for this long post.
