I was messing with the injection pump timing on my '85 K20 6.2L diesel Suburban tonight because there was a little more rattle than I liked. While I had the engine running and moving the fuel pump, I was getting a spark where the advance solenoid touches the throttle linkage. I thought this was odd, and it did this 3-4 times.
I fixed the timing, get in to start the thing and the volt gauge is pegged all the way to the left, well below the 8, I also notice my fuel gauge has gone from 3/4 tank to under 1/2 tank, and when I turn the lights on the reminder buzzer comes on. I could watch the fuel gauge slowly dropping the longer I had it running.
I threw a fluke on the batteries and with it running I am getting 14.1-14.3 volts, my grounds from battery to chassis and battery to engine are good, and the ground from engine to chassis is good. I unhooked the advance solenoid and throttle solenoid and nothing changed. Fuses aren't popped so I know a new ground circuit has just established itself but I have no idea where to start. Any suggestions?
