New engine - which intake??
fried_guy
Fallbrook, CA
I'm building a new engine for my 77 blazer.
I've got 2 choices for intake manifolds. I have a used (but perfect) performer RPM airgap and a brand new, still in box performer EPS... here's my engine specs.
It's a small block 400 + .030"
Carb is a 670 holley truck avenger.
Camshaft is the comp cams extreme energy 4x4 hydraulic flat tappet cam at 270/278 duration (P/N: 12-243-3).
I'll be using rhoads lifters to increase low end and still have a strong midrange and low-topend.
Heads are dart iron eagle 200cc with 2.05/1.60 undercut valves.
Around 9.1 compression ratio.
The only used part in the engine is the block and it's been modified a bit.
I'm kind of torn because the block is a 400 and can flow more at lower rpms. The RPM airgap flows 1500 - 6500 on a 350. IIRC, a 400 sbc lowers the rpm range of products about 1000 rpm. So it would flow approx idle - 5500?
Anyway, considering the rest of the combo, which manifold would be best?
TIA, Case.
the heads you are using are what dictates flow, not the block. That being said whats your projected max rpm with this motor.
If it were me I would use the air gap manifold. I have never used one but reading about them they seem to be one of the better all around manifolds. I don't think you will change your power band much at all with either one.
I agree, the heads dictate the flow, you are correct, that was mis-stated.
But a larger displacement engine will need more flow than a smaller displacement engine because each stroke pulls in more air throughout the entire rpm band. And, because a larger displacement engine uses more flow than a smaller displacement engine at the same rpm, velocity increases accordingly. That's why if you wanted to keep the same power band in an engine with 10% more displacement, for example, you should "increase" everything else by 10% as well... the heads, the intake manifold, the exhaust, etc... to keep everything in proportion.
I'm not designing this engine with a "max" in mind. As long as it has a high and flat torque band to about 4500 RPM or so.
And... with the epilog above, I think I answered my own question (and you did as well). I think the RPM air gap is the way to go.
Anyone else?
