fried_guy
Registered Member
I'm building a new engine for my 77 blazer.
I've got 2 choices for intake manifolds. I have a used (but perfect) performer RPM airgap and a brand new, still in box performer EPS... here's my engine specs.
It's a small block 400 + .030"
Carb is a 670 holley truck avenger.
Camshaft is the comp cams extreme energy 4x4 hydraulic flat tappet cam at 270/278 duration (P/N: 12-243-3).
I'll be using rhoads lifters to increase low end and still have a strong midrange and low-topend.
Heads are dart iron eagle 200cc with 2.05/1.60 undercut valves.
Around 9.1 compression ratio.
The only used part in the engine is the block and it's been modified a bit.
I'm kind of torn because the block is a 400 and can flow more at lower rpms. The RPM airgap flows 1500 - 6500 on a 350. IIRC, a 400 sbc lowers the rpm range of products about 1000 rpm. So it would flow approx idle - 5500?
Anyway, considering the rest of the combo, which manifold would be best?
TIA, Case.
TIA, Case.
