Okay, Cali has some strict smog laws but I don't live there anymore. Kentucky has no smog. I need to upgrade my exhaust, dual 2" with a semi built 400 and stock log manifolds just doesn't cut it. Wanting to go up to 2.5" duals, probably glasspacks. Engine has World Products Torquer 2.02 heads with roller rockers, Jegs intake, Qjet, Pertronix ignition, Comp Cams Xtreme energy 4x4 cam, Moroso oil pan with crank scraper, stock pistons and a reconditioned crank. So that being said, I would like to delete the smog pump, EGR valve and the AIR hoses and fittings. Not really to gain power but just to clean up and simplify the engine compartment. Thinking of at least Rams Horn manifolds but I am not against headers if I know they will fit properly, ie. No interference problems. Doug Thorleys would be nice but I have only seen them in the 1k range. I know the Jimmy is not going to be a speed demon but I want it to breathe. What are some decent Rams Horn manifolds? Prices seem to be ultra cheap to 300 ish. So what are some decent headers that are between 300 and 1k? I don't mind spending good money on a set of headers IF they fit right. What is the power gain difference between Rams and Thorleys tri Y's? And why don't they make a homebrew header kit? I know for headers you need thick flange and 14 gauge tubes if possible. Anything else I need to look for in headers?
Thanks, Joel
Thanks, Joel
