I agree, steelies are fine. That's what I run right now and they've been on the truck for at least 5 years now. H2's I mentioned because you can usually find them for about the same money as new black steelies...
The disc swap can be done pretty cheap. Check out the vendor forum and you'll find three or four guys that sell the brackets you'll need for between $60 and $100. You can use the old calipers from the 1/2 ton front you already have which just leaves you to find some new rotors for the rear. They're not that spendy either. For the rubber lines I used some spare stock front lines out back. All told I was into my rear disc's for well under $200. If the drum brakes on that 14 need doing you'll be into those brakes for the same money or more anyways...
My advice is to do a bit of searching here on rear disc swaps before spending a cent. You'll save money.
Rene
Rene
