Ok so I get the chance to buy a pretty clean blazer here in the salt belt.
So the guy I got it from forgot to tell me the fuel gauge didn't work. I got in drove home and went heck ya full tank of fuel. Well thats not the case. I drove probally 50 miles and the gauge went down a little and the other night the truck died. So I get it home and the tank is empty but gauge still says full.
1. full gauge says full when tank is empty ?
2. oil pressure gauge is pegged?
I am thinking it's a ground of some form but where do i look?
So i shoot some carb cleaner down the intake and it fires no problem. So I did some searching and found if you hook 12volts to the wire hanging off the fuel pump relay the pump should run? I got nothin. When you hook power to the wire does it still run through the relay ? If so anyway to bypass it? The k5 was running awsome just before all this happend.
