I had 33's on my worn out stock 87 K5 with no rubbing
Your right about that. I only put a few hundred miles on mine a year so It doesn't matter as much to Me. I don't have a ton of money to throw at my truck either so That is also a big factor. The front was already there when I bought mine but had blocks in the rear that broke on me. I ended up getting what I could in the rear I could afford at the time. If I had the money I would totally get the ord spring setup. But I always have many other things I have to spend money on. So as long as mine work for now I'll keep Them on. Some of the off the shelf stuff does offer different spring rates as well. Just have to call them up and ask.@chulisohombre
You are saying that custom springs aren't necessary unless it's for serious off road stuff, but then go on to state that yours rides decent in front (that reads not nice) and stiff in the rear, with off the shelf stuff. That seems to me that you would enjoy custom stuff much more. Especially if you felt the difference from yourself..
My '70 rides so much better on pavement since I ditched the Tuff-country springs, that I don't have any regrets at all!
I just need to get rid of the stiff rear lift springs.
My point is, why settle for something that is just a little cheaper, and not enjoy the end result as much as possible!! ??
When it has to do with something that is experienced EVERY time time the truck moves, don't skimp..
