I need heat in the winter or the windows fog up in the wet weather. luckily they are an easy item to fix on the 6.2L.fail safe t stats are junk. might as well leave it out
If I need to do it again and order it online next time, then I will. This time around I had to go with what was in stock locally.Put a high flow non fail safe in.
Looking through my build thread again, I don't think I ever dug into this and rechecked the calipers. I will put that on the list when I get it back into the shop. Currently this one needs a couple things.After finishing the dash, I rechecked the lug nut torque and all was good. I did notice the driver side brake pads can rock back and forth slightly when rocking the wheel. The passenger side does not do that. The sound was very similar to the noise I'm chasing as well. I'll have to take out apart and look at it closer.
