I wish he went a step further and see just how good the filtration is on each. Not many filters either. Theres another good filter test here.
https://www.evolutionm.net/forums/e...ilter-testing-results-thread-4g63t-4b11t.html
AMSOIL filters are a top tier filter if you don't mind the cost. Royal Purple seems to be on par with the AMSOIL filters and if you can get them for cheaper, you may want to consider swapping out your AMSOIL filter for a Royal Purple. Purolator is a very strong second, if you don't mind the shoddy construction. Stay away from DENSO if you can help it and WIX is a great middle of the road filter if you want reasonable price, very good filtration, respectable surface area and quality construction.
Quote-
Conclusion:
I'll start by saying that I'm pretty happy I did this, as it validates quite a few of my assumptions surrounding filtration efficiency and just who was making filters for whom. AMSOIL is worth the money, so all you guys slanging AMSOIL (apagan01, I'm looking at you) keep on, keepin' on. The Royal Purple filter is also a synthetic, so if you can source one for less than the current AMSOIL filter, you may want to consider it.
I was surprised by just how good the Purolator filter actually was. Being a cellulose + synthetic blend would account for it's filtering efficiency. I think the quality of filtration combined with the surface area of the Purolator filter and the price makes it a really good option for sure. I will say that the quality of construction of the Purolator was quite poor, even the filter arrived with a huge dent in the side. Once I cut it open, I could see just how thin the housing was. Since the filters in the 4G63 sit so low to the ground, all it would take to pop that filter would be a single rock bouncing off the ground if you're not running an under tray.
I was disappointed to see the Mobil 1 filter performing as poorly as a cellulose filter (K&N comes to mind, since they're both made by Champion Laboratories), even though it is also a synthetic blend similar to the Purolator. I also found that the filter construction from all of the Champion Laboratories were pretty poor. I'm saddened by the fact that AMSOIL switched to them to build their current Ea15k20, as that's the filter they now stock.
If you can get your hands on an Ea046, that's the filter to get. The lack of surface area in the Ea046 is a bummer, but the filtration quality makes it totally worth it.
I had expected the DENSO to perform poorly and it didn't disappoint. The construction of the filter felt pretty decent, but looking at the internals and the filter design lead me to believe that it wasn't going to do well. I will say that having all of that surface area will allow you to catch quite a bit of contaminants, but what good will that do if it's only catching particulates over 30μm?
The other filters I was pulling for were just average. The WIX, Donaldson and Hastings seem to be sort of middle of the road filters that will do the job just fine if you're okay with settling for average. The surface area of the WIX and Hastings beat out the Donaldson and the higher flow rate of the WIX beats out the Hastings. The quality of construction of all three is top notch. These filters should be fine for your average daily driven car that would see regular oil change intervals.
