new salad bowl air cleaner plate
that's why I be going multi port f.i...I have an Edelbrock multi point conversion that uses the stock TBI throttle body, minus the injectors...
Sounds good. Is it sequential like it should be, or bank fire like my Ford?
I imagine it's batch fire, as it uses the stock ecm. They send a new chip.
I'm going with a TPI ecm & harness...
DaveW is doing something similar with a LS 411 ecm...he has an interesting thread in the injection section.
Just to throw this in, there have been times in the past when things were made too smooth.
Nothing you folks are doing is going to get to that extreme, but some turbulence is necessary to help mix the fuel and air and keep them mixed to the cyli
thats once the air and fuel are mixed... thats why you polish the exhaust side and not the intake... i'd be curious if howdiy has noticed any difference with his swirl cut intake side.. tho he has no base to compare it to...
Google CFM Tech. It is the first one on the page. I just came from there, but paid no attention to the actual website name.
there made by hypertech.heres a summit link there cheaper there.http://www.summitracing.com/parts/HYP-4001/
I didn`t notice a difference in power with this or the pod spacer.it sounds good in theory.you might have to make a taller air cleaner stud like i did it raises the air cleaner assembly up about 1/2"
I got mine from summit. I normally don't order things like these cause I always assumed they didn't help much but I've heard good things from guys here and i had to bump my order price up a little to get 20 % off my order so I almost paid nothing for it
I got mine from summit. i had to bump my order price up a little to get 20 % off my order so I almost paid nothing for it
Do you happen to have a promo code for this, I'm getting ready to order one of these and some exhaust stuff. Thanks
