newlyblzed
hello guys. My name is Brian, brand new to the site and I just recently bought my first off road rig. I bought a 1980 k5 blazer off a friend for pretty cheap. It is a little sluggish though and I want to start upgrading it. it runs a 350 that sounds great with 109000 miles or so. it has a lift but I don't know how big and runs 35 rubber. The 350 has a hard time pushing it but I don't think it is the engine..I think it is in the gearing. Running in 4 low the truck jumps and scoots but in 4 hi or 2wd it has a hard time climbing even the small hills. I already went throuhg and did a tune up (compression at every cylinder was 150 +/- 5 psi) and am in the proccess of rebuilding or replacing the carb. Engine work is my cup of tea...I don't know anything about the rear end and gears, how do I tell whats in it and what do I want to switch to for improved torque?
thanks
thanks
, I have been addicted from day 1. I come here every single day unless Im on travel for work. this site is a wealth of info. you can restore to stock or build a full tilt rock crawling monster with the help of this site. what you do with your imagination is up to you. post up some pics for sure. there are good people here. I have met and wheeled with some cool, really good guys. good luck on your build.
. i'll do it the lazy way: jack up rear end, spin tire, and count how many times the d-shaft rotates. good way to estimate.
.i just realized the post is from 03 not 07!!! don't really expect to hear back on that one!!! duh!
