dezertxj88
Newbie
Hello Ck5. I come from a world slightly smaller
I've always been into jeeps, and currently drive a Cherokee..Xj, 5speed 4x4. I was curious if you guys could help me on the value deal here..I'm thinking of trading my jeep, for a 82 burb..I'll list whats done to the jeep & list whatever I can about the burb.
I've rebuilt almost everything on the Xj! EVERYTHING LISTED IS NEW AS OF LATE July 2011. Its a 1988, 5speed, 4.0, 4x4, Laredo! Its got a 3" OME lift..coils & leafs. Hss 31" tires around 60%, 2 years old., manual locks & windows, cruise control working A/C & heat.
Drivetrain- 94' D30 non-dsico with chromo's, 01' 29spline c8.25 rear axle with rebuilt LSD, 100% rebuilt-hubs, u joints, seals & bearings, ect. 3.73 gears. New from dealer ax15, np231 rebuilt/upgrade with 6 gear planetary & 1.25" fast chain. Original short block with 242K, rebuilt & gasket matched High output head swapped at 238K. 60mm Tb, Updated 4hole "703" injectors, 2.5" Magnaflow HF cat & muffler. Ironman 1/4" Motor mounts, poly trans mount.
Interior- front seats refoamed, seat covers steamed clean, ZERO stains, floors bedlined, 100% new carpet, new headliner, Alpine deck & tweeters, sony explode speakers, Everything works!
Extras- HD 1.5" solid steering, update "open" cooling system, Zj Hd fan clutch, New Luk Gold clutch, new pilot & slave, new master. New brakes, hubs, ball joints ect. New starter, new & upwound 145A alt, upgrade all mains & grounds to 0gauge & a 200A ANL fuse, durango steering box & 3/16" spacer, CB hooked up & working, gas tank skid, all maitenance since July 2011 was done with receipts.
5speed, 3.73's & 31's make it a dream in town & on the highway..18/23-24 mpg..about 20 combined.
Everything is 100% new as of July 2011, maybe 5-6K on it all since then..242K, HO head rebuilt & swapped at 238k. Compression was 151+- across the board at 238k, straight body/clean title, paints alright for being 24 years old. NO rust! I use it for trail running/exploring & camping...however its kind of small with 4 people & gear inside. So I started looking for burbs and found this & started thinking if it was worth trading my jeep for?
82, 1500, rear barn doors, sm465, 350, np208. says 3/4 axles swapped with 4.10s...7" lift-leafs front/blocks rear & 38's, no A/c, superwinch manual hubs..Needs new power steering pump, rebuilt carb, owner will re-register & smog & deal with the minor problems, or cash on top so I can fix them.
Can't seem to post the CL link
However I would drop it down to around 3" or so and 33's. And use it for my new camping/Expo rig...I'm just wondering I guess common issues, is it a fair trade honestly? I've got ALOT sunk into my jeep..receipts for everything. Trans was 1300 alone, brand new 0 miles. Its litterally been rebuilt from the ground up, except the short block & paint. Doesn't leak a single drop of anything either! I would love to get into a full size, but is it worth the trade? What would be my issue? Common issues? Thinks to look for? I read the read before buying sticky already, but any advice?
Should I be asking for cash on top & still have him fix the issues?
I've always been into jeeps, and currently drive a Cherokee..Xj, 5speed 4x4. I was curious if you guys could help me on the value deal here..I'm thinking of trading my jeep, for a 82 burb..I'll list whats done to the jeep & list whatever I can about the burb. I've rebuilt almost everything on the Xj! EVERYTHING LISTED IS NEW AS OF LATE July 2011. Its a 1988, 5speed, 4.0, 4x4, Laredo! Its got a 3" OME lift..coils & leafs. Hss 31" tires around 60%, 2 years old., manual locks & windows, cruise control working A/C & heat.
