I picked up an 87 Jimmy from craigslist with a TBI 350 700R4 and supposed rebuilt transfer case and tranny. What was supposed to be a simple rear diff leak and broken speedo turned out to be a cracked transfer case from a new model Blazer with electric speedo output. It also had a bit of an erratic idle but did not show any trouble codes. Turns out most of the light bulbs and sockets were removed from the dash and now that is fixed.
I ordered a new correct np208 and speedo gear. Turns out not only was the speedo gear unhooked from the transfer case but also from the back of the speedo and the VSS sensor was not plugged in. I plugged it back into the speedo and got the speedo going as well.
At highway speed the truck doesn't seem to be working as hard as it did but doesn't seem to have as much power unless you really kick it down. The cruise still does not work. When the motor is cold it runs like crap until it warms up and does the usual smoking that is probably bad valve seals.
I have replaced the distributor cap rotor button and plugs but still have the erratic idle and crappy response especially when its cold.
