New (to me) shop.
82355
1 ton status
Bradish Nebraska
My brother and I, and a friend pooled together and bought a quarter of land a year ago last fall. I had a bunch of pictures of the place that I took, but lost my phone, and all of the pictures with it unfortunately. The farm had probably been really nice thirty plus years ago, but had not been taken care of. There was a house, sixteen outbuildings, a grain bin, and a silage bunker. The only thing worth saving was the silage bunker, and one steel building. It was a machine shed set up for grain flat storage. When we took possession, it was divided into four grain sections, and a machine storage portion in the front. The grain storage sections had several hundred bushels of rotten corn and jars. Lots and lots of jars. The front was full of junk. All manners of junk. As were most of the sheds.
My wife and I had decided to put up our new house on our forty acres. So I wanted to move the steel building onto the same dry corner as the house.
First I had to clean it out. It was a mess. Here are some of the jars set out on the center dividing wall after I took down most of the tin. There were more. A lot more. That corn behind it was covering boxes of buried mason jars.
Here you can see the front side of the shed with my ‘85 K20 parked inside. I can’t remember what the measurements are. I’ll have to look them up. It’s like 34’ wide, and 44’ deep.
Here is the rear center after I cleaned it out. The center dividing wall was steel with tin. The front to back dividing walls were made out of ship lap. The bottom ship lap pieces were 2”x12”. I had no idea the made ship lap that big.
This is the Northwest section before I cleaned it out. It was a crappy job.
About half cleaning out. That aeration tube was buried in there.
Cleaned out, and divider wall taken down. That was tricky.
This is the neighbor who bought the land with us, helping me take it apart.
Using his telehandler to remove the ship lap. His wife wanted it. We pulled some out of some other barns, but those pictures are gone.
Next came the hard part. Taking all the hardware loose that was holding the shed down to the concrete.
Martin
Almost every nut used in this sheds construction was a square but. Because someone once thought that was a good idea.
They were wrong.
I bought a $400 set of eight point sockets to take it apart. It was money well spent. I didn’t get any pictures of this part of the job, but it sucked. Square nuts are awful. Square nuts that have been buried in rotten corn for forty years are even worse.
The next step was to lift the shed in the air a couple feet, and roll some 50’ REA poles under it to act as skids. That telehandler was awful helpful.
Luckily, I was also able to use my old man’s loader tractor, and the neighbor’s loader tractor. Here you can see the REA pole before we rolled it under the side wall of the shed.
In this picture the South wall is set back down on the REA pole, and the North wall is still on the concrete pad.
The outer tin walls should be replaced eventually, so we just stabbed the lift forks through the tin, and under the red iron to lift the shed from the outside.
View from under. Here you can see the only place hex nuts were actually used. Tho attach the red iron pieces.
Now both wall are sitting on REA pole “skids”.
We ended up cross tying the walls with braces, chains, and cables to stiffen it up for the move, but I must not have taken any pictures of that.
View from the front of the shed getting ready to move.
Southwest corner of shed.
South wall of shed on skids.
Martin
Southeast corner of shed.
Closer.
.......and obligatory poser shots.
The loader was used to push the REA pole under the shed. A 50’ REA pole is pretty heavy. Even an old rotten one.
Ain’t she a beaut?
I guess I got a couple pictures of some of the bracing.
Martin
Moved to just West of its final resting place.
Still sitting on the skids.
The concrete pad where the shed use to sit.
Breaking up the concrete.
We killed a LOT of rats.
Got it moved just in time. There comes the planter.
Martin
My wife’s Jeep parked out front.
Footings dug, finishing the grade. My new to me 2005 Suburban in the back ground.
Footings poured. My old to me (and everyone else) 1975 K5 Blazer in the background.
New pad poured.
Shed pulled onto the pad, but still on the skids.
Lifting the shed, and rolling out the REA pole on the South wall (use to be the North wall).
Rolling the REA pole out from under the North wall.
Martin
Sunk our new well on the North side of shed.
Airlifting the well.
I ended up helping sinking the pump.
Trenching in power to the shed.
My first repair job in the shed. I had to put an injection pump on my new to me 3010.
Martin
Did you consider sitting the building on the footer then pouring the pad inside?
It would have been more work to pour the pad that way. Then I would have lost overhead space. Plus then it would have been more work to replace the tin if I ever get around to it.
....but no, I never actually thought of it till you just mentioned it.
Martin
My quonset garage came with square nuts for the 5/16" bolts that hold the arches together...they are probably used because they are cheaper and might have more surface area to increase holding power..
I hate them too--they would suck to remove in the future,glad I do not plan on ever doing so..
Looks like you've had plenty to do the past year you've been absent !..
Welcome back..:)
That is a lot of work, but you obviously put a lot of thought into it to reduce the effort and opportunity for calamity. Job well done sir! I cant help but marvel at the quality of that soil, that is some incredible stuff right there.
Martin
I think I couldn't of resisted the 10/22 on that one. But then it would of taken me longer to clean up....
When you said new shop I thought you moved yourself to it, not moved it to your new location. Nice work, looks like its turning out good, some new siding and you'd never know the difference!
You and my father are the only people I've known to move an old building on their own to another location to reuse. I helped him do that to an old shed he turned into a game room when I was a teenager so he could used the exposed ceiling of the old shed since it was all wooden rafters, barn wood, etc.
neat.... how far and easy was that to drag?
About a quarter mile. It went from the center of the field, to the Southeast corner of the field. It had to go to make room for the center pivot irrigation system. It was also turned end for end (the door was on the West side, and is now on the East side), so we made a large gentle turn while moving it.
It drug really easy. Of course we used two small, mechanical front wheel drive tractors to pull it, and did the whole thing in first gear, with the engine just off idle. It wasn’t going very far, so we weren’t in a hurry.
Martin
Thank you. For the price I paid, it better be good soil!
We harvested our first crop off of it last fall. It was an ok crop, not great, but we did a LOT of work to it to make it all farmable, so it will be a few years before it really gets going.
Martin
