this is one big thing your gonna want to figure out as soon as you get your trailer im about to get rig of the straps and chain to the frame only right now here is how im running
i run a strap to the axle in the back and a strap across the hitch to keep the bounce down now im gonna chain to the frame only...
With that method there is no really good side-to-side securement of the load. First I think it's hard to use one strap, or one chain, or secure both the left and right sides of the vehicle. I use a good strap at each corner, crossing over in an "X" (right side axle tube to left side of trailer) etc...
I strap my stuff to the axles and pulled out at an angle to each corner, with no straps on the body. I also only use latching straps connected to axle straps (short straps with d-rings on the ends). When I had a race truck, I sometimes strapped axles, sometimes strapped rollcage and pulled it down really tight. Never had a problem either way. The biggest problems I've seen were from using open hooks that came off when the vehicle bounced. I don't cross my straps, because I've seen too many straps frayed from rubbing together, but I do agree with an angled pull if you can do it.
