xCaliK5x
Well after a long battle with the K5, I hurt, but I had to let it go, even after doing so much work to it. My weekends are too busy for wheeling, the Mrs. hated riding and getting in it, plus, I'm short selling my house and going back to an apartment, so the K5 had no where to park since it didn't fit in the one car garage. I will get another one someday.
In the mean time, I got this. I know it lacks ground clearance, t-case and front axle, but I figured you guys would appreciate it.
Its a 1980 C10. I got it from the second owner, OG Cali truck, bone dry. It has a mild worked over 350 thats 5 months old, and an SM465 with a new clutch and 12 bolt rear end and dual tanks. All the moldings have been shaved, as have the drip rails. Paint is probably a decade old and is starting to crack, it will need to be repainted at somepoint, but in the duration, I will get it buffed out, these shots are before wax and a good detail.
I also got with the deal, another 4 bolt main block, 2.02 camel hump heads, a new Summit 388 stroker set with forged rods and pistons, Lunati Voodoo cam, crane roller rockers.
My plans, fix the speedo, temp, battery, and oil pressure gauges. Hook up the A/C and replace the heater core. Get rid of the Boyd knockoffs Circa 1997 and get some 8x15 and 10x15 Rally wheels with flat caps, Line-X the bed, tint the glass, redo the door panels, headliner, dash. First thing to go is the exhaust. I'm going to do headers and a nice setup all the way out. I also need to get some sort of limited slip in the rear since its a peg leg. It runs like a champ!
In the mean time, I got this. I know it lacks ground clearance, t-case and front axle, but I figured you guys would appreciate it. Its a 1980 C10. I got it from the second owner, OG Cali truck, bone dry. It has a mild worked over 350 thats 5 months old, and an SM465 with a new clutch and 12 bolt rear end and dual tanks. All the moldings have been shaved, as have the drip rails. Paint is probably a decade old and is starting to crack, it will need to be repainted at somepoint, but in the duration, I will get it buffed out, these shots are before wax and a good detail.
. Im suprised the wife didnt like the blazer all the girls round here ive talked to love my 76 k5 especially when its covered in mud
