nice gm tilt column rebuild write up/ color pic / with cut away view
That's on here somewhere.
You should change the title of this thread to help searches in the future.
yes masser :1zhelp:
been since the real early 2000's since i had to tear one down for a 4 star bolt tighten up job .
bolts went tight with brake cleaner / red loctight . but the left side key/slider thingy for the ignition switch rod from key movement was bent and popping off a lot from all the slop it had for years before i got it . good thing i had parts unit .
I gotta get back in mine to put that weird little plastic part for the high beam rod back in. I'm not particularly looking forward to it
Posted that link over 8 times here or more within last 2 years.
Even gave links to parts links with link to tool to remove pivit pins on sides.
I have tore my column now to bare housing to repair it.
You can also or crown parts for a jeep to repair certain things in column.
Will try to did up post were I have them out
Posted in both these recently on rebuilding/understanding
Lock cylinder problem and tilt shifter adjuster
We need a sticky on this among other topics to.
Took me forever to get that part aligned and installed. It fell out while disassembling and wasn’t sure how to do it. Of course I didn’t have any service to check online where I was working. Good luck.
