'88 K5 Blazer Custom Deluxe, basic rubber floor mat truck. TBI 350, hydro clutch 465/208, 3.42 open. I bought it from the original owner, very well cared for, oil every 3k, trans/t-case/diffs serviced regularly. New clutch at 60K. I bought truck with 83K on it in Jan 2005, it now has 102K. 32/11.50 Pro Comp A/T's have little over 10K on 'em, still plenty of meat left. I have replaced the fuel pump, fuel filter, and fuel pump relay since I've had it. Fires right up 100 above or (forbid it be) 10 below. It doesn't leak either. I have the original white steelies and 235/75's to go with it. The bad: It blows a puff of smoke when you first start it up. It will use a quart of oil in 3-4 tanks of fuel. It has Blazer rust on the floor by the tailgate. Bumpers are bent. I did the front, previous owner did the rear. Overall it's a nice Blazer and has been super reliable. $3500 buys it. Call if you'd like my name is Kevin. (303)-663-9154. Thanks.
