My daughters '04 Frontier is running poorly and stalling under a load. It's thrown several codes that I've tried searching but the returns seem to be a consolidation of popular reasons and are not specific. For instance, P0303 code is a misfire but the related reasons list A) ignition parts B) fuel injectors or harness C) EGR D) low fuel pressure - wtf? That kind of info feels like any direction I go is a Hail Mary repair.
'04 Nissan Frontier 2wd XE 3.3 V6 NON-supercharged
P0303 cylinder 3 misfire ???
P0328 knock sensor
P0400 EGR flow ???
P0430 catalyst system efficiency below threshold (bank 2) ???
Any suggestions? Even a good resource to search would help.
P0328 knock sensor
P0400 EGR flow ???
You were supposed to reply with an easy widget swap that would fix it all. I've never done it but I assume the injectors would be easy to swap but not exactly a quick job.
