Don't most nitrous systems these days work with a gas pedal activated switch. You arm the nitrous and then the vehicle must be floored to activate it. Which most have some other way of injecting additional fuel. So I dont get the comment.
Sure, most kits come configured that way I suppose. And if you install it according to the way it was designed, then the problem with it being activated under low RPMs is eliminated.
But, if you look around this site, you might find one or two instances of things being installed slightly differently from the way they were intended.
Non stock parts being used.
In creative ways.
So that little switch under the gas pedal finds its self on the dash, strapped to the side of the floor shifter, mounted on a dongle if its in a movie, or its a steering wheel mounted switch.
And sooner or later it gets pressed at the wrong time.
As for the gas comment, naturally the installation includes a auxiliary supply of gasoline. Usually a spray nozzle hooked to the fuel pump.
My mention was concerning what would happen if the fuel pump were to glitch or the fuel filter got stopped up.
If you are running normally, and the fuel supply bobbles for a second, the engine stumbles. Nothing fatal. You might not even notice.
If you are running nitrous, the engine detonates.
That was my point.
