what that means is 12.77 volts found it easier to go through your meter to ground, than the main ground cable. that is bad news. means high resistance on the ground circuit.
If you had seen .5 volts or less that would prove a good ground circuit. works on positive side too.
Is called a voltage drop test.
electricity is like water, it wants to find the easiest path back to it's neutral level.
