I when to start my 90 Jimmy and I turn the key to the 1st position and let the fuel pump prime, them I go to start it and I get a loud clicking sound for a second and no crank. I turn it off and try again but this time there are no lights on the dash and no electrical works. I checked all the fuses, battery and they were all good. I figure it is the starter solenoid so I get a replacement. I installed it today and it fired right up and ran like a dream. I get it back to the garage after a short drive and I turn it off. To see if I had solved the problem I try to turn it on again and the same loud clicking and no crank return. I threw the towel in for the day and decided I would seek advice from the all-knowing forum. You guys have helped my greatly before hopefully, you can again. Thanks in advance.
Andrew
Andrew
