They seemed to work fine before yesterday. I checked the 15a fuse labeled "turn & BU" and for 12 volts at the terminal, and all good. Fuse is brand new and good. I then checked for power at the flasher relay, 12v. Same with the hazard flasher, it has voltage. Swapped out flashers for brand new unit and same result. Headlights and tail lights all work fine, no other electrical issues.
In other news I put Alcan springs in the front, and did the 63" rear spring swap. Fox shocks in the front, reservoir style Edelbrock rear shocks. With the redhead steering gear this thing steers and drives like a dream, probably as good or better than my 2005 2500HD.
