ddy
Registered Member
So I'm back with my "20 years ago pre-smog only" engine experience.
I'm trying to move the truck to the place I'm going to pull the heads off (see my recent post), but now it won't start.
I pulled a plug and checked for fire by hooking up the wire, touching the threads of the plug an exhaust manifold bolt, and turning her over. No spark. I'm hoping that's a valid way to test... I'm used to what must be really old style plug wires where you can slip the boot back and hold the metal loop inside close to an engine bolt.
Anyway I don't know anything about electronic ignition, but I figured I'd test for spark by putting a plug into the end of the wire that goes to the center of the distributor cap and trying to see any kind of arc while turning it over...
Nothing.
Should I see spark using these methods? Do I have a bad coil or whatever they call it in EI?
Thanks for your reading (and your patience).
Maybe I'll get the system administrator to let me change my username to K5n00b!
-Daniel
Nothing.
-Daniel
