Help.
Truck ran and died as I was parking it.
Now I have none of the stuff in the title. It will crank, but the fuel pump is not running when I turn the truck to run. Jump the relay and pump runs.
So I know that the problem for starting the truck is getting power from ECM to the relay, but I seem to have no power anywehre.
All the fuses are good. I've replaced or bypassed all the fusible links....
Replaced the ignition control module.
There was an alarm, I removed it. The crazy thing was that when I was messing with that, it did go into alarm mode, and triggered the hazards while I had the truck in run, I could hear the fuel pump priming each time the hazards and headlights flashed....cant make that happen now though.
This is cross posted in the injection section, but I'm stuck here.
