DizturbedOne
I searched, but found nothing with results. I'll try to give a few details... The truck ran decently fine before I put new plugs, wires, and cap on it.
It stumbled when I first gave it gas sometimes, more so when cold, and sometimes it would diesel for 1 to 2 seconds on shutdown. That's why I decided to do a little tune-up before maybe taking a stab at some Q-Jet tuning. It has H.E.I. also. I've never owned a carb'ed vehicle before this one.
The old cap looked new from the P.O., but the plugs and wires were old. I gapped the plugs to .050 not knowing but have since found the sticker on the air cleaner touting the 400sbc gap to be .045 so I don't see that being a problem. There were two plugs listed for my truck, one being 13/16th head and the other being a 5/8th's with a tapered seat. I ended up picking up the 5/8ths without knowing which they were, but the old ended up being the 13/16th. Think I should try those? They threaded just fine, but the plugs are shorter than the old plugs. I see fuel/air mixture out of the carb when I turn it over, and I can smell gas after trying to start it for awhile. The choke has always worked ok and seems to be working fine now.
I thought it was just flooded since the pump arm was pumped a couple times while working on it, but even after overnight it still isn't starting.
Also
New starter from the P.O. is shimmed wrong so I can't even turn it over enough to be 100% sure it isn't just flooded or something. It was a non issue before because the truck just fired up instantly everytime. I'm going to shim it correctly in the morning and see if I can get it started with some more turning over (which it didn't need before), any suggestions on what could have gone wrong with just a tune up?
Also
