installed a used nv4500 in our 1977 3/4. seems transmission is noisy when idleing and clutch pedal not depress. are they noisy or should i get a bearing kit? i have the right oil. will try a can off gear dope!
Yep pilot bearing or input bearing. Release bearing should only be turning when clutch peddle is pushed in though. If though sound changes when pushing the clutch in and out when idle in neutral. You can narrow it down.
Was this a retro fit swap? Or a straight r and r? Do you have the correct pilot bearing installed?
ya that will cause a rattle too. I’ve been twisting wrenches for 25 years and have heard plenty of rattles that sound like internal transmission problems or even internal engine noise when only a release bearing rattlign around. Not just on NV4500’s but on just about any manual trans model you could think of. I’ve even seen them where they even sound like the engine has a rod knocking.
!!! thats when we notice if we slacken bolts a bit transmission would turn. so we removed about 1/8 of and inch on input shaft ,and finaly got a clutch pedal release. but maybe it but some stress on bearings
!!! next time we work on it, will feel the throw out fork by hand too see if it vibrates. and check end play for safety! but after cutting tip we could turn transmission easly by hand. its sitting over our old pit maybe take a picture tommorrow.
