noob needs help
b89
Registered Member
ark
Ok some of the studs are messed up on thr rear 10bolt. I have never done anything on a axle. i took the cover off and i think i see the snap ring for the axleshaft. you do have to pull the shaft right? I dont know what im doing. so any help would be great.
If you are talking wheel studs, you can take the drum off and knock them out of the axle with a hammer, then use a lug nut and a big nut to pull the new stud in. Or you can pull the 5/16 head bolt out of the carrier in the diff, drop the pin, pull the c clip, then pull the axle out and do the studs.
Yes thats what i did and i just got done. Thanks for the help
