Hi, my names Nick, and I'm kinda new to non-fuel injected, big engine trucks (my previous cars were a '71 superbeetle and an '88 crx
I recently purchased an '81 Jimmy, and I am starting to have some problems with it. It came with an inline 6 and 3 speed on the floor. Recently, a kind of clicking noise has started coming from my engine bay. It sounds like it could be a lifter, but when adjusting the valves I noticed nothing out of the ordinary. I next moved on to the rod bearings, which, while in need of replacement, apparently weren't the cause of the noise, and while cleaning the oil pan out before reinstalling it, I found several small chunks of metal at the bottom of the pan, not enough to get sucked through the filter, and definitely not recognizable.
So here I am, stuck, not sure whether its worth getting a new set of cam and lifters and seeing if thats the problem, or just saying forget it and swapping in a new motor, rather than pour money into a bad one. Opinions on what the noise is or if I should fix this engine?
Also, if I should put a new engine in, should I stick with the inline 6 or go with a basic chevy 350? Thanks for any help given up front
-Nick
). I recently purchased an '81 Jimmy, and I am starting to have some problems with it. It came with an inline 6 and 3 speed on the floor. Recently, a kind of clicking noise has started coming from my engine bay. It sounds like it could be a lifter, but when adjusting the valves I noticed nothing out of the ordinary. I next moved on to the rod bearings, which, while in need of replacement, apparently weren't the cause of the noise, and while cleaning the oil pan out before reinstalling it, I found several small chunks of metal at the bottom of the pan, not enough to get sucked through the filter, and definitely not recognizable.
-Nick
