Haven't tried to use this hoist on the K5 before, but now that I'm stuck with an immovable truck in the way of moving anything around, I find out this hoist is about a foot too short. It's a 1 ton model my Dad got from Harbor Freight quite awhile back, apparently the two ton version (which looks identical online FWIW) has about another foot of reach.
With the manual trans, I can see trying to use the crane as-is as an exercise in tool throwing futility. I don't have a removable floor pan, so the engine will need to go almost straight down on the motor mounts to line up, and there is no way to do that with this hoist.
I COULD pull off the bumper and core support, but I was really hoping not to. The entire problem is the ram hitting the front of the truck, so unless I somehow extend the boom, which I consider a bad idea, removing the core support and bumper are the only other ideas I can come up with. And I always cringe thinking about removing those dang bumper bolts. Not that the core support mounts are fun either.
Considered removing the tires and dropping it down on the floor with the floor jack, but I don't think even that would give me the reach I need.
Someone always has crazy tricks for situations like this, figure I'd ask before resigning myself to more disassembly.
