Factory 4.56 srw.
Workin on a truss this weekend. I've got some pretty cool ideas...stay tuned!
The 4Runner is finally being delivered this weekend as well. Yay! Been alooong time since I could think about building another rig...Feels gooooood!
on the right trail again
Leaf spring setup temporary though. Good 1.25 rod ends for a link setup are expensive... My cost $90 for the big 1.25" Summit Machine Jimmy Joint.
When the time comes, the leaf spring mounts will be modified into coil bucket things, or air shock mounts. I've also got a pretty cool idea for the top link mounts...Keeping with the idea of not breaking the profile of the truss as it is now.
muddermilitia said:u planning on adding any speed holes to it? looks killer btw
cybrfire said:
That will allow the spring perches to pivot a small amount. I'll also be building a pretty cool wrap bar centered over the chunk. The truss will be tied into the pinion support housing with a large piece of 3/8" plate, leaving me a perfect flat spot to build a wrap bar off of. That should take away 95% of the "wrapping" force that the bolts on the pivot mount would see if there were no wrap bar.
, but it sounds cool!!!
