Not sure what is wrong.
Just pulled it out not sure if you can use here are a few pics I see damage.
If you want for parts pay shipping is all I could ask honestly.
28-spline?
I have an 8.5" open carrier if you wanna upgrade away from the gov-lock.
The carriers fragment on the gov-locks, too.
He cheated this morning...
Yep. Ran down to the local greasy swap yard. First truck was a 1985 K10'. Front end had been cannibalized. Walk to the back and there is a glorious 10 bolt laying on the ground. Roll it over and the cover plate is still on it. I zip it open, battery powered tools are the best, and it has an open carrier. Just what I was looking for. I can get gears for an open carrier. Got it out and cleaned it up right there. Bearings, spider gears and the carrier pin look great.
Got it home and did more cleaning. Put my ring gear on it. Spent some time getting the pattern correct. As good as used gears can be. Just waiting for the gear oil to settle out in the tubes so I can finish filling it. Should be good to go.
Now I just need to sell it. I have a boat and a Buick who need the funds.
Under $100 with the parts, gasket and fluid. Now I need to decide if it is worth it to fix the AC. Just were a pump and charge.
