Nothing electrical works
Tattood08
Jacksonville, FL
I can usually figure these things out by lurking the forums but I'm stumped today. 1990 suburban, 5.7 TBI stock except exhaust, 700r4, 4x4, battery Napa AGM 7 months old 12.6v. I've had zero electrical problems over my year of ownership. Yesterday drove it all over San Diego running around with no issues. Starting from my last stop I was turning it over as my son shut the pass door and it dies, completely. No lights, no fuel pump nothing, completely dead electrically. I've been working this all day.
With the bulkhead connector off:
Batt, Alternator, Starter, distribution next to brake booster, #2 pin on connector all 12.6
Grounds from battery to truck and engine are good. Cut out fuseable next to starter and hard-wired it (I know)
With the bulkhead connected they drop to 8-9 volts?
I can't find any damaged or grounded wires in the dash, and no blown fuses. Disconnected the headlight switch and ignition switch with no change. The courtesy light circuit is bus connected to the the tail, horn and clock fuses (always hot) and will put a ground at the alternator so I disconnected it but, everything is still dead. Could the ECM cause this? Sometimes the door open key in will whine real weak but that's it.
I have the gmc wiring diagrams thanks to someones post, but I'm stumped. I'm sure there is something I'm missing, its easy to get lost in the wiring.
Post up in the main garage. Same systems as the trucks.
Did you check both fuse able wires off starter post?
Seems like the main feed to the interior is having issues
I did, I thought thats where I posted. Never posted before. I far as I can tell there's only one fuseable (red) and then the purple to ignition.
check battery connections. they need to be free of corrosion an TIGHT!
Check the ignition switch connection at the base of the steering column.
Check ground wires.
