elyon
Just installed this tach/ fuel gauge. In my opinion the truck should have come with one as standard. I knew there had to be an aftermarket option out there somewhere.....
link? P/N?Online at GMsports. out in CA.
I had to take a dremel to the back of the gauge cluster house a little bit. Otherwise no changes needed.
I put this factory one in my '89. This is the light duty truck tach. Hard to come by but not impossible.
thay are miss representing the item .
its font /color/style is for 80-91 .
so if you want correct looking for 78-older dont get it .
It is plug and play.
There are 3 pins on the back just like the original for the fuel gauge. Just one wire to the distributor or coil for the tach. piece of cake!![]()
