NP 205/D60 owners
84_Chevy_K10
Banned
IL, USA
Anyone know what size socket to remove the pinion nut on a D60 front?
Also, same question for the rear output of my 205.
I'm thinking it's in the 1 5/16-1 3/8 range
if ya dont get a response to this from someone that knows off the top of their head, PM me, I'll get out a caliper and climb under the rig...
j
jek, if you could do that just to double check, i've got to go on a 25 mile round trip to buy the socket since mine stop at 1 1/4", it'd be appreciated.
I'm thinking 1 5/16 is correct as well
Got calipers? Put a caliper on it, or make do with a pair of needle nose vice or something. Adjust till it touches, pull it off, and measure. Should easily be able to get within +/- 1/32 which would be close enough.
Only calipers I own are at my work, sitting on the parts counter. /forums/images/graemlins/frown.gif
well thats what worked /forums/images/graemlins/whistling.gif
just needed some grinding on the socket /forums/images/graemlins/ignore.gif
-shawn
Beat me to it, I just went ahead and pulled the shaft to check... /forums/images/graemlins/laugh.gif
Has to be thin wall 1 5/16" as well. I had a hell of time finding one at the time I needed it to get my pinion off my front 60. /forums/images/graemlins/tongue.gif
I got a generic 3/4" drive chrome 12 point 1 5/16" socket and it worked fine.
Damn the Sears here, NO INDIVIDUAL SOCKETS!!!!!! What kinda crap is that???
I got a generic harbor freight 3/4" drive kit. The 1-5/16 wrked fine. I don't thik they are truly a thin wall design.
Same thing I used for mine.
BTW, Matt, do you still need that D60 1310 yoke? If so, I've still got it for you...
makes you wonder if I was "using the standards of C.E.E."
/forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif
[ QUOTE ]
[/ QUOTE ]
When that's not quite right, get a bigger hammer for the final adjustment!! /forums/images/graemlins/dunno.gif
